1 - 6 of 6 Posts
i need to fit a fog light to my rod. Is there a fog light that looks ok ? Dont want a square one.
You could use a square one but use a swivel bracket so it can be pushed back underneath when not needed .Or fit it far enough back underneath that it isn't readily obvious.
Another option is a magnetic base... I have a high-intensity light for the Shedster (with a tiny car and no lights it makes sense to have something for when it's pouring down on the motorway to stop the trucks running right over you...) and I mounted it on a CB aerial base (cheap off ebay), and keep it under the seat. Couple wires to a double pin connector, and a couple wired into the car, and all I do is stick it on the back and plug it in. Been a potential lifesaver with all the torrential downpours we've driven through this year......:tup:
1 - 6 of 6 Posts
