Ford 351 Windsor V8 engine for rebuild - £200
1 reading
3.2K views 8 replies 6 participants last post by  69Mach1
#1 · (Edited)
I have for sale a Ford 351 Windsor V8 engine for rebuild.
The engine is dismantled for inspection/rebuild. The block is 1979 date coded (D9AE-6015-ED-24). There is the block, heads, crank, damper, pistons and rods, cam, timing cover, timing chain, lifters, oil pump and pick up, sump pan, valve covers.
The block/pistons are +40 and the crank is +10.
Not 100% complete but a good base for an engine build.
The block, heads, crank, sump, timing cover etc are loosely put together to ease transport and storage.
Cheap to clear - £200
Call Derek 07986 911636
You have insufficient privileges to reply here.
