FORD 460 C6 HIGH STALL HEAVY DUTY 12" TORQUE CONVERTER, 2200 to 2400 rpm stall depending on your application. Supplied new by Broader Performance Texas Along with new manual bodied C6, converter has seen 300 miles in a cobra replica and that's it, still as new. This has a 1.375" crank pilot for '72 onwards big block Fords with C6, Note: Earlier big block fords had a 1.85" crank pilot requiring a different converter. Collection from Nottingham or can package up and courier for £15. Viewing welcome close to J25 M1. £150
just in case you didn't know small block c6's had that same smaller pilot size too so will fit them also. it was fe big blocks that had the bigger pilot size. :tup:
Hi, Thanks for that its useful to know. It would have gone behind my 460 but I have a 1969 so had to get one with the larger crank pilot to suit.
i know the problem, i have an fe for my race car. it'll have a 'temporary' mild motor to start with so i got a mild convertor and chose the small pilot size as it'll be easier to sell when i build my 'race' motor (it'll fit small block and 385 series which are more common) and upgrade the convertor then. i'll just turn up a spacer ring for this one to suit. i'm surprised you don't do the same and keep this convertor.
