Good as removed 8.8" 'Trac Lok' 28 spline OE LSD, F07W-BA, no known issues £149
Matching 2.73 (15/41) ratio ring & pinion, E95DA & E95?FA, essentially no wear only expected meshing witness £99
Both together £235
In an ideal world you'd replace all bearings, but they're not too bad and would probably go again if you were on a tight budget
As always, sensible close offers considered
Gas Machine Metal Fashion accessory Nickel
Automotive tire Drinkware Pottery Gas Automotive wheel system
Gear Gas Auto part Metal Fashion accessory
Hair Automotive tire Gear Rim Automotive wheel system
Automotive tire Auto part Automotive wheel system Metal Circle
Auto part Coil spring Fashion accessory Metal Electric blue
