Pretty much everything you need to convert earlier four stud Mustang to five stud
All parts from a SN95 mustang, so track is slightly wider when fitted to Fox body
All info online, common upgrade in the USA
Assume all parts need renovation or rebuild, in an ideal world you'd fit new discs but these aren't that bad and at worst could be skimmed
Sorry, job lot ...... won't split
Pair 8.8" 28 spline 5 stud axle shafts, good bearing races with expected minor running witness only
Pair rear 5 stud disc & calipers, with all mounting hardware
Pair front 5 stud hubs & discs ..... no calipers but some if not all Fox calipers apparently fit
All tinwork a little bent, but could be straightened out with patience, or simply discarded
£499 or sensible offers only
Tableware Kitchen utensil Wood Auto part Personal protective equipment
Wood Musical instrument Tool Floor Flooring
Tire Automotive tire Light Tread Synthetic rubber
Wood Auto part Machine Metal Personal protective equipment
Wood Grey Outdoor shoe Sculpture Shoulder plane
Wood Hardwood Metal Auto part Art
Automotive tire Wheel Bicycle part Rim Automotive wheel system
