FORD MUSTANG 200/250 1970-71 TOPLOADER MANUAL GEARBOX PARTS
FLYWHEEL / BELLHOUSING / SEPARATOR PLATE / FORK ARM / ASSOCIATED BOLTS etc etc
ALL LARGE PARTS CLEANED READY TO FIT WITH MINIMAL EXTRA WORK
BELLHOUSING Pt. No. C7ZA 6394 A, MOSTLY SHOT PEENED BACK TO BARE METAL
136 tooth FLYWHEEL, CLUTCH SURFACE QUITE REASONABLE TO USE AS IS, WITH VERY SLIGHT LEADING EDGE WEAR TO RING GEAR TEETH
VERY MINOR WEAR TO PILOT BUSH BUT AGAIN USABLE ENOUGH AS IS
MOST (IF NOT ALL) ASSOCIATED FIXINGS INCLUDED, BUT NEED CLEANING PRIOR TO FITTING
THESE WILL MATE VIRTUALLY ALL CAR 3spd / 4spd TOPLOADERS TO THE 'SMALL BELLHOUSING' 200 / 250 ci 6 CYL ENGINE
WHEN REPLACING THE FRAIL '2.77' 4 BOLT TOP COVER GEARBOX IN UPGRADING TO THE SUBSTANTIALLY STRONGER 3 or 4 spd 'TOPLOADER' 3.03
STD WIDE 'BUTTERFLY' BOLT PATTERN
COSMETICS AS MAY OTHERWISE BE EXPECTED RELATIVE TO AGE & USE, BUT PLEASE BE REALISTIC ..... THESE ARE 50 yo PARTS NOW
