SOLD
302 cubic inch Ford V8 small block engine. Perfect for a Hot Rod, Cobra, Mustang etc, etc
The block is the most desirable 1970/71 version, block number D1OE-6015-AA - 0J16
The engine IS on a test stand, it can be seen & heard running, it has excellent oil pressure 55-65 psi & sounds great.
It has just undergone a complete rebuild by us and has the following:
Crankshaft ground -10 thou
ARP high performance main cap bolts
New standard bore pistons, pins & rings
New bearings throughout
Block honed
New freeze plugs
New camshaft bearings installed
New Edelbrock performer camshaft
New Cloyes timing chain and gears
New 'Pro Street' balancer
Choice of four barrel Holley 650cfm or four barrel Edelbrock 600cfm carburetor
Edelbrock 14" chrome air filter
Edelbrock Performer 289 intake manifold
Mallory Dual point distributor
New Moroso Blue Max spark plug leads or MSD if you prefer
New Champion RF11YC spark plugs
New high volume Melling oil pump and pickup arm
New ARP heavy duty oil pump shaft
New hydraulic lifters
New pushrods
New Competition Cams Valve springs
1.773" intake valves
1.442" exhaust valves
New valve stem seals
New ARP high performance head bolts
New Edelbrock Chrome valve covers
New water pump
Holley high performance mechanical fuel pump
Moroso High performance Coil
Fram screw on oil filter
Competition Cams SAE 10W-30 break in oil with additive
New aluminium finned sump
Ford Motorsports high performance Aluminium pulley set
Ford starter motor
Not included are the alternator, exhausts and bellhousing shown in the images
We are located in Southall, Middlesex UB2 5NB and are open Mon-Fri 8.00am-5.00pm and Saturday by arrangement.
Please call anytime if you have any questions.
07429 118638
£5750.00 ono
Thanks for looking
Watch the engine running here, copy and paste this link into Dropbox, you will need to open a free account if you don't already have one
https://www.dropbox.com/home/302 ford
Thats exactly what i was thinking, Reel Steel do a 360 bhp for £3800
And thats with Ali heads
That's true, but the real steel engine is just a long block, there is still around £2000 of carb, intake, manifold, pulleys, headers etc to go on top of the £3800 long-block plus labour to put it all together.
