hi all i got a morris minor with a standard 4" 102mm pcd spacing hub (with the bearings in it )
just wondering is there any other car with the same fitting and size but with 108mm pcd (4stud) as i was gonna weld mine up and retap but its cast so weld dont go if im correct
thanks
Banjo snapper.
Get in touch with Trevd on here, he specialises in this sort of thing.
can buy conversion kits to put discs up front from most of the moggy suppliers out there as upgrading to ford stuff seams to be the way or better still get your steels banded for that wide option
