Chevy 350 CID V8 5.7 L 2 Bolt Mains Completely Reconditioned Engine with all New Parts listed and Machined Components, Suitable for any Chevy Replacement project or AC Cobra or kit Car Project.
New gaskets & Seals, New Hypereutectic Sealed Power Flat Top Pistons with Rings 0.030 Oversize, New Mains & Big End King Bearings on 0.010" Undersize, New cam bearings & Timing chain kit.
New Melling MTC-1 Performer Cam shaft with lifters, New Oil Pump, Sump, Oil switch, and Oil Filter, New long Water pump. Edelbrock Chrome Tappet, Timing, Fuel Pump covers, dip stick tube, and Assembled with all New stainless steel Bolts, harmonic damper Bolt, New Spark Plugs, New ally water pump and damper pulleys and Alternator adjusting bracket.
New stainless steel valves 1.94" inlet. 1.5" exhaust + 0.003 O/Size, with New Valve Spring and Seals.
Reground crank shaft to 0.010" Under size. Rebored Block to 0.030", All Con Rod checked and Aligned, Fitted pistons to Con-Rods, Fit New Cam Bearings, Reface valve seat & lap in New Valves, Skimmed Cylinder Heads.
New Hi Rised inlet manifold with good 600 cfm Holley carburetor, 1" carb spacer, Edelbrock air cleaner, New HEI distributor with Leeds, New PCV Valve, Chrome water outlet and thermostat, Manual 168 teeth flywheel, New starter, New Alternator, New 4 into 1 Headers,
Block casting no 3970010 2 Bolt Mains, Crank casting no. 3932442
Cylinder Heads Casting No. 333882 76 CC Chambers 1.9" inlet & 1.5" exhaust valves C.R 9.5 : 1
plus fully reconditioned autobox just been done suplus to my needs however. new torque convertor,kickdown cable dipstick etc
the fly wheel on the picture has changed to automatic flywheel, new billet pulley at the front. message me for more pics
basically a turn key engine and box
engine can be seen running on test stand
For any further information phone or text me on. 0781 7522 014 or on. 0773 9579715. I will get back to you ASAP.
4850- or nearest offer
