1 - 16 of 16 Posts
CAN ANYONE TELL ME WHAT GEARBOXES THESE ARE. I WAS TOLD THEY WERE CHEVY TH350 BUT THE GOOD ONE I BOUGHT WON'T FIT IN PLACE OF MY BROKEN ONE. THE MOUNTING HOLES ARE DIFFERENT AND BELLHOUSING THE WRONG SHAPE THE INPUT SHAFT HAS ABOUT 4mm DIFFERANCE IN LENGTH
GEARBOX 1
GEARBOX 2
CHEERS JIM
buick 215 was i think the base for the rover, that being the case you need a BOP and yes the above would be correct.
Can you find the serial numbers there on 1-2 accumalator cover looks like a core plug with 4 vanes coming off it and the governor cover.Can you click your caps lock as people might think your shouting and take offence .Also you can get dual cases,being as your is super charged i would ask the seller for the same info.
Discussion Starter · #12 · (Edited)
there are no numbers on the box only this welded in the casing
sorry about the caps thing, i get on better using computors like this
If it's any help the holes on the tail shaft are for a rear axle torque arm ,that might find which car it came out of.My head hurts now:mooooh:
1 - 16 of 16 Posts
