Due to a gearbox change I am looking to change the mountings. I am fitting a four speed Reliant box to a Ford 10 upright engine and this bit has been done apart from successfully fitting it into the car. The original rubber mountings are a tight fit on my fabricated brackets. I am hoping I can find some mounts that are smaller diameter rubber. Looking on ebay I saw Cortina and Landrover Discovery mounts look possible but would appreciate if somebody could give me size of the mounts so I can compare. Will put picture and size of my Ford mounts here later today in case you have other suggestions. Cheers, Dave
So here is more info, the rubber is 2 3/4"/70mm diameter and the steel base cup is 3"/75mm diameter. Overall height is 34mm.
