Its an old hop up trick that makes the dynaflow perform better,by increasing the high accumulator's LONG spring pressure.......To increase the power and decrease slippage in the trans...
I did it on my old 55 and the results were pretty sweet.
Procedure is as follows:Firstly ensure the trans is in good condition, bands correctly tightened - Find the High accumulator - Remove the original spring (long one) and replaced it with 1982 Chevy 2.5 oil pump spring (available in Chevy oil pump rebuildkit). The accumulator does not have to be taken off the car...
Improves power transfer through the trans and helps get these big ol' barges hustling
I will try to find the pix i took when i did the original spring swap
