pulled the pan twice to try to cure the leak out of the gasket rail. Put on a new thicker gasket METICULOUSLY installed and still it leaks. I did not put sealer on gasket as I understand you are not supposed to. When the fluid drains down into the pan on turning off the engine it is going to be above the pan gasket surface right? I dont even know if I have the correct dipstick as it was already in the truck when I bought it.Maybe its over full.....any ideas as to why it keeps leaking??
