complete kit comprising of
2 billet ali hubs drilled to accept jag / chevy 5 stud wheels (correct cetre location, not relying on the studs to centre the wheel. designed and stress tested to ensure safety, manufactured from aircraft spec materials (not run if the mill aluminium)designed to use original bearings and seals.
2 caliper mounting brackets
all necessary fixings
comprehensive instructions
the kit is designed to use ford capri (mk 2 or 3) vented disks and escort Mk3 callipers.
the kit will not work with 13" wheels.
the set available are in bare aluminium(not anodised as in the pic)
kit does not include disks, callipers, brake hozes or viva spindle.
£275 the set
