hi guys/gals its a long read but please help
i got a morris minor yeah yeah i know
with what i think is a ford escort mk2 rear axle
i was a idiot and over drifted and curbed it BENT HALF SHAFT
the one i had was 25.5 inchs long end to end
hub locater depth 0.5cm
and bearing thickness 1.5cm
i brought a set of what i got told mk2/1 and there different
27inchs end to end
hub locater depth 2cm
and bearing was thicker at 2cm
so what have/did i have 25.5
PLEASE HELP
hi @WB54 the width is 120cm and if it helps 9" brakes came with it
If it's got 9" brakes then it could be from a Corsair. It will have 2 piston type brake cylinders if it is from a corsair.
I'm not sure but I think the halfshafts are the same length as a Mk1 cortina.
Hope this helps a bit.
Cheers Denis
is that the axle case width or the distance between the axle flanges isntalled i the case, oh and measure in inchs, no bugger will recognise them in cm's
Anglia 105E is 43in case, 48in axle flange to flange
if 120cm is the case width that sounds like Escort, possibly Mk2 if it has 9in drums.
I've just measured a half shaft from a corsair and it's 25.5" long.
As I said in my previous post I believe the Mk1 cortina shafts are the same length.
If you have a cortina axle the brake cylinders will be the single piston type.
If you have a Corsair axle the cylinders will have 2 pistons.
Cheers Denis
Mk 1 Cortina GT has 9" drums with double cylinders, Corsair and Cotina axles, same width. So it is Mk1 Cortina GT or Corsair maybe MK2 Cortina GT 1600E ?
Martin.
Discussion Starter · #10 ·
yes its got double cylinders, so am i looking for Corsair and Cotina half shafts
YOU LOT ARE STARS
next anyone got a halfshaft for sale ifnot a pair 25.5inch
