Here goes,
Thought I gad it all sorted, all the bits I need, high comp heads, also domed pistons, couple of cams, etc etc.
It then turns out that the heads that I was sold as HC heads were not, they too have a large cc.
Ok, that means I can use my dome top trw's and run NA with my tunnel ram etc etc, 10.3ish :1, fab.
I have been offered another set of SCJ heads with the big valves and with stock pistons will give about 9.4:1 again, good.
Dome tops with scj heads over 14.8:1 no good for the street.
My last moggy was TT and I loved it. Totally mental, loved it.
As you've worked out, seen tt set up for sale and it has got my mind whirring.
The deciding factor will be if I bought them. Then that would then set thing sout for me.
If not, I have the chioce of running flat tops and small CC or dome top and large cc.
Can you see the dilema I'm now in.
Why is nothing ever simple?
Well if I do get the TT's then I'll have a lovely set of 12CC forged TRW speed pro pistons up for grabs and a set of ally rods and matching gudgeon pins up for grabs.
Discussion Starter · #7 ·
If you haven't already heard, my mind was made up for me as I've bought a twin turbo set up so need low compression.
Yee Haa!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
