1 - 15 of 15 Posts
as above...im trying to suss out what this is at the back of my newly acquired caravans toilet compartment...:confused:
at the rear of a water container...
any ideas???:shake:
cheers...al
Discussion Starter · #7 ·
Al try henrys revenge he breaks/repars caravans .how are you mate messing about again karens just had scan results all stable
hi...gary (henrys revenge) was on the phone for an hour last night...and we're still none the wiser...he hasnt seen one before...
my problem is...its a german built DETHLEFFS caravan...it has 12v and 220v fittings...
i know where to attach the 220 supply,but i havnt found anywhere to connect a 12v battery...theres no wiring going into the lift up front panel,where the gas bottle goes,but i have dual voltage lighting in the kitchen and toilet and a 3 way fridge...i'll just have to try and trace the wiring a bit more...
i did run a new 12v supply into the caravan...so at least i have some 12v lighting and a 3 way skt for charging phones etc,but i would like to get the fitted stuff working...
thats great news about karen...tell her to wrap up well in this weather... my doc was happy with me yesterday too...cant believe its nearly 3 years since i was diagnosed...i think im over the illness...just need to get over the cure now...
im hoping to do some of the shows/runs this year...but really need to keep warm...i seem to get every cold/flu thats going coz the immune system is low after the chemo...
so im selling the combicamp and gonna roll in my heated caravan...the pop should cope with it ok...
cheers...al
Banned
What,s the bet it,s a kama battery box ? looks like the top un screws .... is there a small rechargeable battery inside and this gives multi take of,s ?
power taken out to your taps ????
the micro switch for your taps will be on the base of the taps,
i may be wrong but i would pop the lid and have a look inside.
Discussion Starter · #13 ·
well story so far...when i have the caravan hooked up to the car and switch the headlights on AND my fog light...i get a 12v supply to the caravan lighting...i'll check to see if theres a supply to the KAMA unit tomorrow...i was busy on the gas today...cooker and heater are working fine...also fitted a new skylight in the loo to replace broken one....makes the living area one look grubby,so thats next to get changed...
i did notice a wire from the KAMA unit heading up behind the sink,so i think the unit is a pump,and the wire goes to a tap microswitch right enough...
cheers...al
Banned
cheers...al
it can,t be a pump with out a water supply ?
1 - 15 of 15 Posts
