I want to put a modern water temp gauge in my truck, like to replace the sensor in the engine block, one with terminal on top to take wire to gauge, could any one tell me what thread that would be in the original brass sensor, theres plenty on net avaliable but I dont know the thread pitch ,ones avaliable state 1/8 npt thread, means nothing to me.,,
Hi Streetbopper.
The best place to check is on Stovebolt.com
If it is the original style bourden tube then it will have an odd thread. Its definitely not 1/8 NPT as they are quite small and I know it not an NPT, UNC or UNF thread.
I think I read somewhere it is a 3/8 gas flare fitting. Its some kind of old school thread.
I had loads of problems trying to get an adapter for the fitting when I swapped for a 235 engine.
I think the best answer is to re-tap the head to a larger, more common thread.
Tap out to 5/8 NPT or 1/2 NPT. And get a suitable adapter for the new temp sender.
Chris.
