1 - 13 of 13 Posts
Administrator
ok i took it for the first little drive and we have a few issues
the rear axle needs new bearings internally and pinion bearings at a minimum as it whines like a piggy
and the steering is so vague its dangerous
the play appears to be in the steering box
would i be better finding a new rear axle (the one that is on the truck is a 5 stud 68 impala)
and can i do anything with the steering box
any ideas on this please
thanks
Steerig boxes can be rebearinged and clearanced. first though, have you ever driven a steering box vehicle before and taking a central point on the steering wheel how much free play in either direction?
Administrator
Discussion Starter · #6 ·
ok on the side of the box i found a nut with a sloted insert in it I've done this up and yes its a lot better now
still a little bit of play but ill re test another day
now what do i do about the rear axle noise
You can overdo the adjustment on a worm and roller type box. It may feel ok in a straight line but see how it feels in corners. It may not self centre.
Rear axle bearings are cheap. If it's whining it's probably the diff. Is it under load or when trailing?
Administrator
Discussion Starter · #9 ·
its the diff bearings or pinion as i did the outer bearings a little while ago
henry the prop is brand new with all new bearings and the gearbox is a fully recon unit
thanks
If you're not used to a steering box it can feel shagged ( compared to rack and pinion) when it's not. The setting you have is MOT acceptable , dependent on steering wheel size. With a box you have o learn to use a loose grip and guide it along, slowly turning the steering slightly before a bend to set it up.
I'm Not Jed Clampett
Is the axle whining on drive, overun or all the time? If you're using an old car rear axle in your truck, you might have to change it out a few times for other secondhand ones till you luck into a good one. 60s/70s yanks will probably have done Starship Enterprise mileage by the time they reach the breakers yard. A new CW & P and bearings for your existing axle would probably work out cheaper -and easier than repeatedly changing out the rear axle.
1 - 13 of 13 Posts
