1 - 6 of 6 Posts
does anyone know how to recalibrate a smiths speedo from a moggy i'v read somwhere that u take one apart and adjust the distance between the spinning disc and the magnets is this done by using washers as spacers ?if you move them further apart which way does it adjust the speed i dont want to knock it even further out of cock than it is 10mph at the moment doing 50 indicating 60 dont want to repaint dial and write numbers in biro if i can help it:tup::smoke:
General tool abuser
Could you just remove the needle and re-position it back 10mph....dont know how accurate it will be lower down though..
a friend once refurbed his bike speedo by repainting the dial and then putting roman numerals on using letraset (rub down and peel off lettering type stuff)
ttfn glenn
1 - 6 of 6 Posts
