Mustang 2 - Speedway Motors, America's Oldest Speed Shop
1. you have stock diameter rotors, 9 1/4 inch - use stock mustang brake calipers
2. you can get the stock rotors in 5 stud ford or chevy, they come with 1/2 '' unf 20 tpi studs.
3. you can directly fit 11'' ford usa rotors, use metric chevy calieprs with a cast caliper adaptor. -widens track 1/2 inch, stock et for mustang 2 is et10mm
4. the taper for the steering ball joint track rod end is 7.2 degrees, if using an imperial steering rod, use the stock mustang 2 - if you need a m14 by 1.5 metric rod end, use a 1995 mustang sn95 tre.
5 it is easier you find the 11'' brake parts than stock mustang 2 stuff.
6. you can simply directly fit wilwwod pro-spindles mustang 2 spindles, that have a bolt on arm that lets you fit the steering arm so its steers from the rear. stock stang 2 is forward fitting.
7. the balljoints are mopar, but when you buy them, if you get them from speedway, then its simply a mustang 2 ball joint for aftermarket use.
8. you need a deep washer on the lower one, as the pin thread / nut bottoms out.
9. the stock wheel base for a stang 2 is only 96 inches, the track - centre of tyres is 54.5''
10 stock the stang 2 ran 13'' wheels, hense the disc diametre is so small, the tyres were 195 70 13 = about 2 foot diameter, if you run a 15 inch wheel you need a 60 sewries profile in order to get a diameteer of about the same 595mm.
11. scrub radii - in order to have the centreline of the tyre bisecting through both the bearings -for load spread, plus of course scrub and the like, you need to match the stock wheels et of 10mm positive, the closest you can get is a 6j wheel with an et of say 5mm - the torque thrust series 105 have this, if you fit a 4.5j rim the plottted line throughthe ball joints will only just touch the inside of the rim, - if using the 60 series tyre 165
the actual stock caliper and mounting are a bit old in terms of design, the concept is rather 1972, i.e. the caliper slides in a trapesoidal 'horse' on the caliper mount, rather than like a modern front calieper.
5.
