MR UN-POPULAR
ive seen the volvo conversion on the nsra site, anyone know another option to get discs onto a pop beem?
Marina /Herald fit with some bearing juggling and a rear spacer. Mart did a conversion using a 105E hub and Sierra disc as well ,probably the best way if you want to fit 15 inch rims so can use Minx rims.
Banned
I'm sure there was a thread over the road covering this, if you can't get it give me a shout and i'll try and pull it back up if i can find it,
Hi Sqweaka. I know you PM'ed me, but here are some shots of my Spitfire brake conversion on the Pop axle, as it was done. It still isn't finished. Hope this helps. The spring washers spacing it are tempory until I get some proper spacers machined.
MR UN-POPULAR
Discussion Starter · #10 ·
just in case anyone else is doing this conversion, bearings are available that are a mix off the pop inner and the 105e outer halfs that allow you to fit the 105e hub to the 103e spindle! the part number you ned for the new bearing is 07098 07210X. got mine from my local bearing supplier for £17.50 each
you still need to make up a small spacer to stop the hub going on the shaft to far but its looking good:tup:
