TechnicalTom
I am looking for an engineering company/ individual to put splines on some thick wall tubing for my planned Torsion bar project, I can fabricate the parts myself , but the broaching of very small quantity is not available locally.The torsion bars I am looking at are Peugeot and( on the standard car )they go into what seems to be cast steel so cutting out and machining parts of the Peugeot rear arms is a no no.
Full Bloody Rebel!
We use a place, Stoners, in Clevedon, but it's a long ways from you Tom! They do standard broached stuff for our valve work, but don't know if they can do internal splining.
I'm Not Jed Clampett
If you have access to a lathe and some changewheels you could broach the splines yourself. This video is of cutting a gear, but the process is the same for internal or external splines.
TechnicalTom
Discussion Starter · #7 ·
I do have a good Harrison 190 Lathe also a small Quantrum Lathe,at the moment our broadband is too slow to view the video above .but I will give it a go,thanks for the great input so far.
I have done all sorts of machining on a lathe, but never tried broaching like that, mainly because I have never thought about it, I have used Minutemans to cut internal keyways, which I suppose is the same process but made easy. as I have been sitting here typing I have thought of a job that I can/might be able to do, :)
