What do you guys use for bump stop on the Jaguar rear axle?
The axle hubs are just outside my frame. I'm planning to do a bump stop on the outside of the frame rail that will hit the top of the hubs.
To reduce the impact forces on the hub I would like some kind of wide rubber piece bump stop formed with an inward radius about the same as the top of the hub, but I'm not sure of this.
Comments or suggestions?
In-between 1932 & 1951
Sorry not the best picture but bottom left hand corner ,made from 1" (25mm) round stock ,drilled and tapped and fitted in picture with a power-flex universal bump stop (since changed to black ones) .I only fitted them as a fail safe if i had a shock or spring failure ,so hub or tyre won't clash with the chassis / rear wing and I'd still be able to move the car ,
Cheers Matt.
