1 - 20 of 30 Posts
Adjusted prices and all are OBO as I need space!
Jag rear sub frame £10
Jag rear wishbones, brand new - £30
Jag wheel bearings and hubs - £30
Jag 10 spline drive shafts, brand new - £35
LT95 gearbox for Rover V8 - £40
Roll cage for pick up trucks - £45
Series truck cab with Defender rear set up so you get a decent window! Roof has got insulation and LED's in the roof - £150
Winch tray (weld in type drilled for Superwinches) - £30
KC Daylighter 150w halogen units in stainless steel, wiring loom included - £150 posted (you cant buy these in the UK anymore, can get bulbs but not the units)
Aluminium 16 gallon fuel tank with mounts 12x12x26" - £100
Toggle switches with the fighter jet style flip cover - £2 each
Starter button panel with switches - £15 and £25 for them (ones bigger than the other and has more switches)
Brand new 26t LT230 input gear, cross drilled- £40
LT230 transfer, 1.22 ratio, needs new input gear and bearings (28t version) - £50
Early 110 ribbed roof with interior light, nice and straight with no dents! - £20
Input shaft for R380 V8, brand new with bearings - £40
Mac tools trolley in red, no dents, set of keys and has liners for the drawers - £250
Discovery steel wheel with tyre, useable as a spare - £15
Series 3 front panel, usual rust along the bottom - £30
Aluminium race radiator, good for a trials car 26x19x2, brand new - £45
Series Landrover steel wheels - £10 each
Slam panel for a trailer landrover or hotrod - £50
Mr Gasket pancake filter in plain chrome, brand new in box - £35 posted
Rover V8 flexplate - £15
Rover V8 engine mounts for the block side - £10
Pacet race fan - £35
Facet solid state fuel race pump for carbs, brand new in box - £30 posted
Chevy 454 cam shaft, looks brand new - £25
Weiand 8v71 blower with front cover plate for idler and drive pulley, just needs snout - £800
Plastic BBC engine covers in red - £5
Chevy Mk4 454 flex plate brand new in packaging - £45
Chevy Gen 6 flywheel, brand new - £45
Landrover screw jacks out of military defenders - £25 each
I think thats the lot, if I find more I'll add it
Discussion Starter · #18 ·
Sorry in all honesty I'd forgotten, its 25 by 18 or thereabouts and its top drivers and bottom passenger
My mate said he'd have it off me yesterday (in all honesty I'd forgotten about your post) so as you had dibs you're welcome to it if its right for your application and I'll tell him that I'd forgotten about you
My mistake
these things happen.
Louie
Hi,
is the Jag rear subframe the original cradle type or a crossmember ?
are the driveshafts 35 for a pair please ?
Louie
1 - 20 of 30 Posts
