im about to brake a mk3 granada, it has disc/disc brakes
will the master cylinder/servo/pedal box set up suit my mk3 zodiac which has capri disc/drum set up
you could be right kev, this would also explain why i cant fid the one from the last granada i broke, i obviously didnt keep it as it was ABS :pmsl:
im guessing capri would be the sam a 4/5 cortina
From memory Cortinas are either 3/4 or 13/16ths dependent on whether 1600 or 2000. It's the bore of the rear cylinders that create the difference .
