Righto chaps and chapesses, I have a problem...
I have started to cap the cut bits on my doors and 1/4 panels, but have come to a bit of a halt with how to do a bit...
Door capped, and B pillar top done too:
Which I am quite chuffed with, but I need to join the bits up now, and it has a strange shape to make, how would you fill this bit in, in keeping with the rest of it:
Would you:
A) weld an 'upright' bit of sheet to the inner skin, and then gently roll it over to meet the other bit, or
B) try and make smaller panels and fill with steel/weld, or
C) another way???
Hope this makes sense...!!!
:beuj:
I'm a grown up drunk!
possibly get a 90deg exhaust bend, the same diameter as the top of the rolled bit behind the door,
thin split that right down the centre with a hacksaw so you've only got half the bend,
you should end up with something similar to the rolled bit you need for the corner,
then pie cut it and generally bash it about till you get the right shape,
does this make sense?
That should have been my C) question... :shake:
Had thought of that, but was trying the 'no money, and use what I have lying around' route first...
Ta though...
:tup:
didn't say it had to be a new bend,
you could always do a late night rummage through your local kwik fit bin?:tup:
True, I have looked through our 'bin' at work, but it's all to thick on the wall...!!!
Compulsive chicken choker
Weld an upright strip to the outer skin, cut it downwards into "fingers" & bend these over to meet the inner skin & weld into place. This will need a *cough* "thin skim of filler" afterwards!
Discussion Starter · #7 ·
What is this strange 'filler' stuff you talk of???
None of that shit going on my car...!!!
Mid England Retrims.
easy one this is , if its a budget build your going for , then a bit of hammer forming is all thats required , get some 1/2" plywood and cut the shape you need , make two patterns , ie image and mirror image so you can sandwich the metal between the two sections then smack it like a bitch with a cross pein hammer to stretch the metal round the former to get the shape you need. ade
Shake it, Hobbes
Second this method, I usually use mdf as it's easier to form with a 'kin great bastard file. If you form a curve on both sides of the mdf former, it will mirror each side better and you don't have to go to the trouble of making two identical formers.:tup:
Andy
Pass the lump hammer
Guy
Bend the thick wall pipe that you can get your hands on to the shape you need and use that as the former to beat thinner sheet metal around.
Easier for you to do than shaping wood or mdf,
Steve
