1 - 20 of 44 Posts
I have a clarke 151te that has started blowing fuses ( in the plug) frequently.
Any idea wgat the oroblem might be?
Using 13a fuse.
put a bit of 6mm bolt in instead of the fuse if its blows the trip throw the welder away
Or give it a bloody good clean. Unplug and clean shit from inside. (Air line or paint brush) check earth lead and gun connection. Check power cable for any damages. Do not stick a bolt in the plug. If it still fails drop me a line chief.
never seen a mig not use a bolt!!!!!!!!!!! lol
im on 2 and 3 phase welders the 3 phase is on a 32amp plug and the 2 phase is on a 64 amp plug!
Sounds like a who knows more then you match. As for my welders bigger then yours match. One of my welders in my bay is bigger then your washing machine and will lay a 6 fillet 18mm multi run on a 50mm thick base plate.
1 - 20 of 44 Posts
