hi all ,my uncle is after the above ,the one he has says shrink on 11/65 on the ring gear & 118e 6375c on the flex plate ,this is a 4 hole fitting ,all the pics on internet show 6 bolt fitting .the ring gear is welded on to the flex plate & has distorted it .is there another flex plate from another ford / car that he can use ,ideas /info /comments all welcome .IAN :tup:
6 bolt fitting is for early Mk2 Cortina 1500 ( yes 1500 which is part crossflow and part precrossflow) and then the later Mk2 Cortina 1600 plus Escort and Cortina crossflows.
Not that I know of, the early Fords are a pain even on a manual to make sure you get matched ring gear and starter motor ( different pinion teeth count).
depends on your level of skill as it could be possible to convert the 6 bolt to fit with a fresh centre or an adapter but whatever thickness could cause issues with depth of torque convertor mating etc..
hi kev ,would you know what gearbox is in this car ,redg is AHR 375B ,it says cortina on the boot & consul on bonnet (change over model) its a 3 sp auto,he says its a c3 ??? i dont think it is ,any ideas
