Hi guys,
Finally bagged a pair of struts with disc setup but only 1 caliper.
Does anybody know what other calipers might fit ?
They have 3 fastening bolts compared to the usual 2 but i did wonder if there was a 2 bolt
caliper that'd fit.
The gap between the 2 outer holes is pretty big at just over 8 inches, (roughly 205mm to some) ;)
Cheers
as far as im aware these were only used on Mk 2 zephyr/ zodiac and nothing is a direct swap, i think they are also handed so you need to make sure you get the correct side. i made brackets to use cortina callipers many years ago for a customer, now i would look at more modern callipers and possibly find later vented disks as well to upgrade the brakes.
Only just seen this but someone onone of the Zephyr facebook groups has said that MGB calipers are the same (I cant vouch for it but got to be worth looking into)
Probably the last car I'd have thought of.
I'll look into it, ta.
(y)
