chrysler 834 axle 293 open diff 4.5 on 5 stud ,has been cut for narrowing needs yoke casing has been degreased and diff too ,not being used now £70
muncie 4 speed competition plus shifter with linkage and long shifter lever excellent shifter £100
edelbrock air filter 5 inch deep x 14 inch diameter chrome good condition £40
sun tacho meter needs a tidy up but works fine £20
1/2 inch unf press in wheel studs extra long at 60 mm arp gold ,£20
2x 165 15 michelin tyres bit perished but usable mint tread £20
276 ring and pinion for 489 chrysler axle comes with yoke £30
07790407551 cheers rodsnsods
Neil, Is the axle still for sale, if so what width face to face was intended with the cut casing. Regards Si...
Discussion Starter · #9 · (Edited)
Hi si at work at mo will measure later m8 and pm you cheers not sure on intended with as bought for diff as parts but think its around 60 inches welded as is never used it in the end so its surplus now
