261 - 273 of 273 Posts
Discussion Starter · #262 ·
Spent ages for not too much, tunnel centre section tick, underfloor supports, getting there, rear engine lift bracket, tick, front flip front hinges welded on, gosh that flip fronts going to need some cutting and shapping, nothing fits :-(
632076
Discussion Starter · #264 ·
Bit more tunnel work done, and starting to think about the brake pedal, through the bottom of the car, or through the fire wall, sort of like the idea of through the firewall to keep the floor clear.
Still a little more welding and grinding, but starting to look better.
632450
632451
Now Pedal Options, through the floor, or ... move it forward and come through the bulkhead.. Hmm.
632452
632453
Discussion Starter · #266 ·
Thanks Mark, yes aiming to have it ready for you once you finish Phil's 😁
Bulkhead mounting gets my vote, so easy to do if you’ve got the space for master cylinders , surely under floor is more prone to dirt and water spray and seized parts.
Discussion Starter · #268 ·
Yes, true. Although the master cylinder is already mounted under the floor and will require a cover so that cover will have to project forward cover the pedal mechanism on either option. :)
Discussion Starter · #269 · (Edited)
A bit slow, but the frames been fitted under the edges, forgot to take a picture, and now the final bits starting to be fitted
632621
Blind nuts and bolts will replace the pins to allow the tunnel to be removable together with the other panels of the floor and prop shaft tunnel.
632623
that's looking nice and always a bonus being removable too.
Discussion Starter · #273 · (Edited)
Floor and tunnel 95%, gear lever linkage done. Now it’s time to move on to the doors, blimey they are a horrid fit.
Tire Automotive tire Motor vehicle Tread Gas
Starting on the passenger side, door gap needed 5mm off the door, it’s starting to get there almost ready to be welded back together
Wood Automotive exterior Gas Wood stain Composite material
Now thebottom of the door needed a chunk out
Wood Composite material Tints and shades Shade Wood stain
And buttered up almost ready for welding
Wood Floor Flooring Hardwood Composite material
the front edge is a bit of a horse’s rear leg, ground a few bits off and coming along, a few bits to build up now
Automotive lighting Hood Automotive tire Grille Motor vehicle
