Rods 'n' Sods banner
1 - 20 of 479 Posts
Discussion Starter #1 (Edited by Moderator)
well that got you looking........... it`s a morris 8 series e . i saw this in my local scrapy and it was to good to leave ... so with some haggling i bought it (26/6/2011)
and thats where it all started i`m hoping that i can do this justise! in the process of hunting for bits to rebuild it, i found another one for parts and when striped down i thought that if there`s enough left over a rat-rod for some fun , over time i`ve learnt that it`s a good idea to get as much as possible before you start, so you can get on without having to waste time.
Discussion Starter #2 (Edited)
i will just let you all know i`m pants on these thing`s (confuser`s that is) so donot hold your breath as it can take me sometime. My job is to build this and your job is to keep me at it and not wonder off for to long:bored:
Hi Bully that is a great find especially from a scrapy ,to good to be crushed ,whats your plans for it ? nice one Cheers Neil :tup:
Discussion Starter #4 (Edited)
well...................... in my mind it's going to be a retro classic but on saying that it`s having a 19 turbo diesel lump out of my citroen xsara, m.g.b front and rear suspension, wire wheel`s, a striped down loom /steering out of said xsara but trying to make it look standard to the joepunter as i'm hoping to have it as my daily drive but the second one is still open to change but will be a rat with a touches of bully :D
hi bully if you,ve got any spare wings or interior bits leftover that you want to sell let me know mate gettin bored of being fenderless .
not 100% sure but with the Citroen /peugeot lumps think you can turn them around and put them on a LDV 200 van gear box or similar, after all the peugeot 405 was front wheel drive and the same engine was turned around 90 deg and put in the LDV 200
Discussion Starter #8 (Edited)
graham your right the (ldv) pilot gearbox will fit, it`s an lt77 box but with slightly lower gear ratio so got an ldv bell housing and as this was the gearbox for most B.L 5 speed car`s in the 80's.I picKed up a TR7 box cheap and now all bolted together fine, but i've now just got to workout the clutch as there`s about 5 different one`s fitted to them
Discussion Starter #9 (Edited)
austinrod theres some wings on fleebay at the mo and he`s on here, the one that was selling the 8 shell nice bloke sold me a twin wiper mec for mine
hiya bully, notice your from oxford, im from oxford aswell :D love the idea of a diesel rat rod, id love to build a sit up and beg prefect with banded wheels, widened fenders with a big dirty diesel in it and left looking rat ;) what scrappers did u find it in btw?
yep spotted them last night! on my watch list ! deisel is definately the way forward especialy where i live! my next project is probably going to be an amazon with a transit lump running on veggie oil .
Discussion Starter #12 (Edited)
right i could go all jackanory now but my finger won't last that long (i am that one finger typist ) my plans for the car is it`s to be my daily drive so has to be easy to source parts when i break it so thats why i choose mgb front cross member and rear axle and at the time an engine as well (until the xsara failed it's mot with tin worm) so now have two cars and two engines that's where the rat-rod started
the second car.
i didn't think to take any photo's when i got it as i thought it was going to be for spares but it was about 60 % there but still no drivers door (since then i've got about 3 drivers doors )
mgb engine and gearbox
i had the chassis sandblasted and as you do, tried the subframe for size. its the right width but just a bit high (i think it was about 18"/20")not going for the gasser look
so i cut the front of the chassis out, mocked up a bit of a jig and welded in the sub-frame to the chassis, and voila.
now the rear is sat at 12", front 8" so as the rear of the chassis had some tin worm in and too high ,so off it comes and a new one went in,i brought some 80 by 40 3mm box i put it on my bike jig to do this, all the cutting was done by the stilsaw in the back of one of the pic. well on the jig i removed the bottom lip of the chassis and put on some 30x30 angle iron . in ready for boxing but forgot to take pics
Discussion Starter #13 (Edited)
hy the car came from smith`s of bloxham thay tend to keep the classic cars sat to one side for a bit
the diesel motors going in the good one they mgb motor going in the rat i thought about putting two threads up one for each car but im going to strugle to keep up with just one
Discussion Starter #14 (Edited)
i put the axle in to try it for size
tried the body and panals to make sure all were in line and if my wheels looked ok
me thinks i might have to widen the rears a bit
the rear cross member in the way so that will be moved but fits well
now this is when my car failed its mot, so out with the engine and try it in
engine sat to far back i'm hopeing to keep it a 4 seater so i chopped out the sub frame
replaced the top bit 20 mm from the bottom the engine now fits (the two bars under it were for support but now will be for steering rack to mount on )
Discussion Starter #15 (Edited)
when i put the engine in i had to remove the intercoler as it sat to far back not a prob will fit a difernt one but the turbo sat abot an inch form the o s shocker so i thought ill do a coil over convershion the rack sat rite under the bottom pully so i thought move the rack if im going to do that ill put the power steering rack from the citroen ....yeer me being a twat if you put a rack from the back of a subfram to the front guess what turn the steering let it go`s right ..... bum i no ill fit a left hand drive one in and turn it round that will work
yer good ider but when i looket for one its rocking horse poo as all the left hand dive cars get bourt and shipet abrod so i solket
but when i was down the scrappy looking for one i soor this and thourt that will do for the ratrod
ok well im looking for the rack ill get on with the ratrod when i bort it one of the frunt hubs were missing but there was a herald sat next to it so i stipet both frunt struts of it and put them in the car there you go all there again with spars lol
nowing that the herald stubaxal is a littal pron to spliting i thought ill have me sume new uprated ones
befor i cut it up i looket to see if it was sume rare ugle thig but no joy so prob just sume old low cost ting
right out with the cordliss four days to drill out all them poxe rivit but lots of ally sheet started to have a good look around it its not a herald but a vitesse based kitcar (bonus ) with triumph 15 fwd hubs on the rear
did sume masuring it a littlelonger but 4" wider so body wont fit ( bum )
i now il cut the chassis to leve frunt and rear supenshion repair the other cassis and drop it in the midal now thats the plan but !!!!
found a lhd rack yepeeeeeeeeeee the blok told me one ov the fixing lugs were brok off no probs my mates a top noch ally welder so of to him
and ill get on with the coilover thats about where im at now
Discussion Starter #16 (Edited)
right fingers rested. over the last three weeks i`ve been building my front suspension as now i`m skint from buying things and the missis is starting to moan :oops:
i`m one of those that thinks if someone else can do that why not me, i`ll have a go .i looked at all the coilover conversions that i could find and drew up some plans. made a wood template for the tower .looked ok so made up some 5mm plates.
i know theres no guard on it but sometimes needs must
when at the scrapy there was a new m.g.b came in, it was an abandoned project all the front had been rebuilt so off it came and home with me :happy:
i stripped off the bottom arm pivots, cut them in half / lugs off then spun them down to 20mm (the biggest drill bit in my box)
made the side plates and bottom plates, tacted them together
the twin towers
i thought i would use the spare bottom arms and cut them down for the top ones, it work`to a fashion but looked pants...and as the bottom arms are under tension and held in by the spring plate(without the spring plate the arms spread and not in line). so.... binned..... and started making some adjustable ones
if you look in the back of one of theres my first arms
still got no money at the mo i`ve found some turnbuckles to go in but will have to wait until funds allow.
might get on with the rat-rod now
Discussion Starter #17
Looks like a good project.
Is the doner car fwd.how will you get round that.
Keep the pics coming as the build progresses
ldv pilot bellhousing lt77 gearbox the same as the 5speed rover v8 one and pilot gear lever remote to keep it foward
Some serious fabrication there fella :tup: not the obvious choice of engine either.
Jeff
Discussion Starter #19 (Edited)
Jeff
thanks for that :bigsmile: i try but this front suspension a bloody nightmare to workout so if im doing anythink wrong im open to suggestion/help or advice
the motor was giving me about 50/60 mpg and theres loads of them around so i can still get spares
1 - 20 of 479 Posts
