481 - 485 of 485 Posts
if you remove the guts from the false rad' cap leaving just the top bit then you can use the overflow pipe fitting to run a battery breather pipe.
Discussion Starter · #483 ·
neil believe it or not that is the reason i put the filler neck in and i can hopefully have the battery fix down bolt/nut under it to plus the raised bit gives me some room for the pos lead /bolt
well done graham , by the way something that would make the engine run cooler is having the vacuum advance working , and making sure it has enough advNCE IN THE DISSY ,EG TIMING CORRECT AND CETRIFUGAL WORKING AS IT SHOULD .oooops caps , not shouting ...promise :)
thanks for that i will definitely check that but as i haven`t seen my car in three months when i get over there again i will check
Discussion Starter · #484 ·
We have a little bit of progress the second rad and the battery box are now fitted it didn't go according to plan but as I made them from memory they only needed a small amount of fettling
631245
There's a rad in their somewhere
631246
From underneath and to help with the water flow i have modified both rad drain plugs and linked them together should help with the flow
And the battery box
631250
631251
631252
Now to start putting it back together
Civic rad should be enough as they are a hot running engine and by putting it on end you get an increase of 30% in cooling efficiency.
You may find the additional rad CAUSES overheating :( Reason being is that the extra volume, without the aid of gravity may cause the water pump to 'stall' and not push ith around enough . It will certianly help with heat soak when you switch a running engine off and all block heat immediately transfers to the water system .
Used to be my 'game' for 17 years ;)
