For the last two days I have been making this floor frame to fit on the Kitten chassis for when the time comes to put the A35 bodyshell on with the new floor I will make from sheet. I won't get it MIG welded to the chassis until I am ready with the Austin body shell to go onto the chassis (ages), but I thought it was something to get on with. It isn't finished, as you can see the cross peice tacked on in the middle where the prop will go through, and also the peice crossing over at the back, which will be cut aswell once I get the second arch on. I have grinded all the arc welds down, and made them flush on the faces and curved at the right angles. The pictures are just of the frame mocked up against the chassis and clamped; nothing lined up or measured in relation to the chassis in the photos.
