Well it would have been a busy week if the tyres had turned up.... (to55ers) the battery did, and was promptly returned; you really have to be a major optimist to put a vented lead acid battery with a courier, and expect them to keep it "this way up " at all times …..
Repaired the wooden roof supports as the were broken, when removed (2 years ago), all 8 of the bolts that hold them in snapped off, and so they all had to be drilled out, and re tapped, what a lovely job!
Finally welded in the boot floor closing plate, mig wire run out almost immediately, and so had to tig all of it; you cant even see it, (but exhaust fumes will find their way in no doubt) finally rivetted rear panel on.
Note the boot latch handle, a BMC mini item, that was cheap (ish) because it had no key (and is in the locked position) I wasn't too bothered as I have loads of keys (or so I thought) but what I do have, don't fit!
