Ready for a bit of a mental mechanical challenge? Try your hand at understanding how the D-Drive works. Steve Durnin's ingenious new gearbox design is infinitely variable - that is, with your motor running at a constant speed, the D-Drive transmission can smoothly transition from top gear all the way through neutral and into reverse. It doesn't need a clutch, it doesn't use any friction drive components, and the power is always transmitted through strong, reliable gear teeth. In fact, it's a potential revolution in transmission technology - it could be pretty much the holy grail of gearboxes... if only it wasn't so diabolically hard to explain.
More at Gizmag
Haven't got time to watch the vid but it sounds like a system Williams were trying out in F1 years ago. It was a variable drive cone like a Daf Variomatic!(remember them).
Engine note stays the same as it was always in it's power band.
Didn't catch on.
Looks to be a combination of a straght thru shaft and a simple harmonic drive? out side does gear reduction, middle does constant speed, combination of the 2 gives you veriation in range.
Pass the mechano... I'll get me coat...............
seems pretty simple to me but is that because i am an engineer or because i am half cut?
i do like the simplicity of it but to handle motoring demands i think it would become a lot more complex as no motor company can make anything with less than 3 computers
ttfn glenn
drag race addict
It's a very simple idea,but it needed someone to actually think about it.
As the guy said a plastic model is all well and good and "in theory" the real thing should work. I'd say that the middle gears would need to be a lot bigger than they are now and to lube eccentric rotating gears on shafts will be a bit tricky in the long term.
Fair play to the fella. A plumber has beaten a lot of the brightest engineers to this method of driving wheels..
