350 olds motor needs rebuild
Stripped this motor down last week to check it after being told by guy i bought it off "yeah its a good runner!" C**T!
bores are fine except for no 8 which has some scoring down it
block has a thin crack in water way by no 2 cylinder ,That then carries down block in valleyway , crack is about 100mm long
main bearings are worn as well, thats as far as ive gone taking it apart
complete motor including 4 barrel inlet manifold
£175
Cant upload pics at moment please call 07436 260761 or email : [email protected]
for pics
thanks
Danny
Danny you you put a liner in the block, if its a pre 76 engine it will have bores that can be rebored to 4.125 with a check and a reasonably stout bottom end. if its after 76 its not so desirable.
i have a 403 olds for rebuild in good nick though £450
