1 - 14 of 14 Posts
Hi,Can anybody tell which paint I should use on bare steel, i have only ever used two pack primer before but have heard a lot about epoxy primers (DP90?). Should i use etching primer then primer surfacer or epoxy then primer surfacer?. And anyone know where i can get it from as my local paint supply guy has never heard of it. I Normally paint all my cars and have never had any problems just wondered if its better for longevity and what benefits it has. Any advice would be appreciated.
Official Drag Addict....
use hammerite bob.
Sid.
just acid, epoxy it bob we can get it if needed pal
Colin ,Have used that Lechler etching primer (jeez that stuff makes your chest bad!!) then two pack primer, Is the epoxy better at holding back any corrosion due to having a high zinc content? Just want to know what folk think as a lot of the yanks seem to use DP90 epoxy
2k Epoxy and then normal 2k filler primer everytime time Bob, I'll sent you the product numbers, and your nearest suplier tomorrow morning ,Bry
cw motors paint and body
hi bob just come back on epoxy or a good zinc spray then a good 2pack primer like bry said give paint and panel a ring not for from you 0161 3435343 ask for harrold or paul at colourtone stockport . is the 34 ready for primer now bob
Discussion Starter · #11 ·
Now comments like that scare me, don't you wear a mask?????
As Bry said, epoxy & primer filler is the best way.
Yeh i wear a mask not a air fed one but not some cheap thing either (get new filters every time) ,just seems to effect me kinda makes my chest tight for a couple of days.don't have a problem with anything else just that lechlar stuff, but i take on board what your saying. I take it the epoxy takes the place of the etching primer and you use body filler on top of that?
Discussion Starter · #12 ·
All the bottom 6" and floor is done all round and up and rolling:D
Discussion Starter · #14 ·
tryed phoneing you today pal had paul in from colourtone he has the stuff you are after.
Hi Colin, Yes mate ,you left a message I did get it but its on my works phone so didn't notice till just now !!! not been in work today had to have dental surgury, wisdom teeth out.:cry:
1 - 14 of 14 Posts
