Fairly complete (I think!) front brkes from a Pop. Includes shoes, cylinders, wide 5 drums and backing plates. What you see pictured is what you get pretty much. The cables were cut, so need replacing, and two of the four brake shoes have had metal ears welded to them (pictured), so they will presumely need grinding back or replacing if you want to use them again. Only comes with two of the four bearings. As I say, I don't know how much of it there is here, so it I can't call it complete, but most of its here. Oh, and the little clear box of nuts and things in the photo might have the odd Triumph Spitfire parts in as well as some Pop parts, because I put Triumph Spit discs on my Pop spindles and ended up throwing both Triumph and Ford parts in the same box!
£20 the lot. I live in South Somerset, near Yeovil. PM if interested.
