This isn't car related, but I guess folks on here have more technical expertise than the Indian company I'm trying to work with.....:wanker:
One of our products is a cast iron lid that is then powder coated and has to provide insulation up to 1kV. The first samples that I approved were nice and smooth with a decent thick powdercoated finish that passed the 1kV withstand test. The production parts are as rough as a badgers arse with powder coating that you can practically see through. They fail the 1kV insulation test easily.....
Is there any pre-coating (a primer of some kind?) that can be done before powder coating to smooth out the cast iron surface? Or is there a way of controling the powder coating thickness???? The rough cast iron surface is causing the (already thin!!!) powder coating to thin out on the "peaks" of the surface and provide very little insulation.
