Discussion Starter #1
hi all, just after a anglia 105e prop, need the prop and the axle end, mating up to a garanny box, got the sliding yoke already, for the lad, thanks john..
Banjo snapper.
I've got a load of props here John but I'm not 100% sure what you're after, is it a complete Anglia prop you need? There's two different diameters of diff flange, one's pretty rare.
Discussion Starter #3
thanks
hi , we took the axle of a 1966 ford anglia 105e, cheers john, ps are u goin to the hot rod drags..
Banjo snapper.
It'd be best if you measure the diameter of the axle flange mate, just to be on the safe side. I'm not going to the Drags but a mate is. Still need to know exactly what you're after though!
Is it you that's got the giveaway Fordson?
