1 - 11 of 11 Posts
Dragging not Bragging
Ive seen things for a reverse pattern (valve body :?:) but does that reverse the whole gear box or just the forward gears
I was wondering if it was possible to swap the forward gears only so instead of R,N,D,2,1 you could have R,N,1,2,D :beuj:
Were talking the good old Th350 and maybe the 700R4
I wish this snow would melt cos then my brain would get a rest :beuj: its starting to hurt now :shake:
Vin, next time we see each other take JJ for a spin, and see what a pain in the arse it is on the street :shake:
Forgot to mention, theres no `D` mines P R N 1 2 3 you still have to change up and down the box manually :sniff:
The Camino Kid
Tony, You've got a manual valve body as well as a reverse shift pattern, but you already know that...lol. I don't really see the point with these modifications unless you're going for what they were designed for, primarily racing. As Tony says, on the street they can be a pain in the arse as with higher stall converters in street applications. Personally i'd forget about the 350 and 700r4 and go for a 'glide. Ya cant get a more reliable, robust simple trans in my opinion.
drag race addict
What do you want to do with the car? how much power?
someone has already answered your question on gear patterns.
surely it cant be that much of a pain to drive on the road? i mean if it was a manual car u would have to have a clutch and change gear more times!
jim
Got salt
A manual valve body without a reverse pattern can be a real pain in the arse! Especially with a ratchet shifter.
Having to ratchet thru all the gears to go from neutral to first and back just isn't on.
Discussion Starter · #10 ·
I think Briz is on my wave length here why go from neutral to 3d surely Neutral to 1st would be better
And if your racing and you floor it then g force pushes you back so why fight it and push the lever (shifter) forward :beuj:
Reverse pattern manual valve bodies are no problem at all on the street, been doing it for the last 20 odd years. You do need a good shifter though. Forward pattern manual is asking for trouble in a racing situation, missing 3rd and getting neutral or reverse instead ain't much fun.
1 - 11 of 11 Posts
