Dishwasher worked for 18 years, stops suddenly, plugs into another socket works, socket won't work for anything but elmo tests and it's live. It doesn't trip the fuse board, any ideas
Semi Proffessional Prat
When Elmo test did he use meter or screwdriver with neon.
Should have 240 L to N, and 240 L to E.
If socket has been changed and still no good, then the problem will probably be in next socket in line. Loose connection in that one. Very unlikely to be a broken wire between sockets.
Gym Junkie
I had a socket that just stopped working tested OK but wouldn't nothing plugged in would work, replaced socket and it worked fine, examined the faulty socket but couldn't see anything obvious so chucked it in the bin.
Administrator
ok a few things to check
are there 2 of each colour wire if so its part of the ring and very unlikely to of lost both neutrals
if there is only 1 of each wire then its more likely , especially is you have done any re decorating and maybe moved another socket
im a electrician by trade so if i can advise you or him further drop me a pm and ill send you my mobile number
but as above its more likely the neutral has failed wither on this socket or the 1 before it
is the washing machine under a cabinet with a switched spur above it
13A Switched Spur - Switches & Sockets - Electrical -Tools, Electrical & Plumbing - Wickes
a looking similar to the one in the link ?
