1 - 12 of 12 Posts
Looking for an external fuel pump to run a Holley 390. The car has a square Facet on ATM and I've had enough of the noise !!!!
Can anyone advise a pump that will gives off a lot less hummmmmm ?
is it rubber mounted on cotton reel type mounts? those square ones are usually pretty quiet.
in my experience it's the other way round the cylinder ones are always much noisier (but last longer)
Fit a decent mechanical one then it's zero noise.
Discussion Starter · #7 ·
Yes it's mounted on those button rubbers.
I knew this wasn't going to be simple one answer thread :-(
Carter electric pumps are pretty good. Used them many years ago and was very pleased with how quiet they were. Had both the regular one and the higher pressure one.
1 - 12 of 12 Posts
