Had originally got this lot to convert my 8 inch axle to rear discs but have since swapped for a 9 inch with wilwood discs so this is no longer needed. This is the kit I have: SN-95 Rear Disc Conversion Adapter Brackets. Mine is the V6/GT kit. I have the discs, pads, callipers, back plates, adaptor brackets and the correct braided hoses for the conversion. The kit does actually just fit under the stock 14 steel rims. The only thing I don't have is the handbrake cables that are made specially for the conversion which mustangs unlimited sell for less than £100. I've repainted the callipers red and the back plates in white and haven't been used since painted. The discs and pads are almost new. The rest is brand new never used. The kit works with any 8 or 9 inch rear axle that uses the small bearing axle ends. £250 takes the whole lot. Prefer collection as its heavy but can post at buyers expense if your patient. Based in essex.
Thanks for looking,
Chris.
Thanks for looking,
Chris.
