1 - 16 of 16 Posts
Hi all, Busy re-wiring my 49 chevy truck, using a rebel wiring kit, but i'm going to need to reduce the voltage to the heater blower ( recon about 4 amps) and the gauges/feul guage. I can source the necessary parts in the states, but have drawn a blank over here so far, Anyone out ther know of any supplier over here please ?? Regards,,Gaz
Thanks Darren, was makin sure that whatever there was that would reduce the voltage, would handle the amperage, . thanks for link, hopeng for a uk supplier, but looks like am gonna have to be patient !
I'm Not Jed Clampett
to provide 6V @ 4 amps from a 12V supply you'll need a 1.5 ohm resistor like this: 5% 50W 1.5 Ohm Chassis Mount Wirewound Aluminium Housed Resistor | eBay it needs to be bolted to a metal surface to act as a heat sink, mine is fitted to the top of the heater box - but mine is there with some other electrickery to provide a two speed fan.
Arithmetic is voltage to drop divided by desired current in circuit = series resistor value. So 6V ÷ 4A = 1.5Ω
Voltage dropping resistors only work in a circuit where the current is constant, so not really any good for fuel gauges etc. Digital converters like the one Darren has linked are ideal for low current stuff.
Semi Proffessional Prat
A resistor ( or dropper) as described will only work if the resistance of the dropper is the same as the resistance of the motor it is feeding.
A better way would be a solid state dropper, that gets fed with 12 volts, and give 6 volts out. Much the same way as a 24 volt to 12 volt dropper for lorries to run 12 volt accessories.
Fuel gauge dropper is relatively easy also, providing you are on negative earth, and can use a soldering iron.
If you use one of the classic batteries with external bars across the top you can tap off 6 volts at the mid point. The 6 volt tap is either + or - depending on which end of the battery you put the other connector. I got mine professionally tapped by Lincon at no extra as far as I recall. The 6 volt line has its own fused circuit and powers the fuel gauge and semaphore solenoids and I would think it could deal with much more than you need. Dave
That or run two six volt batteries in series , then just pull the six volt supply off one of them and the car still gets the 12 volts off the pair. Nothing else needed.
Bob
Can't you change the motor for a 12 volt one?
Rekindled Dream
:yeahthat: beat me to it. :shake:
1 - 16 of 16 Posts
