v8 in 100e,the cable from holley comes round on its self and into the bulkhead side as the v8 in 100e comes into the car abit,This is a bw65 so a kickdown is connected,.Now there seems to be resistance in pedal obviously pulling 2 cables,Is this expected cause it dont feel tight to me
The kickdown cable shouldn't have that much resistance. If it were me I would temprarily disconnect that, try the pedal, if it's the same it's not the kickdown cable causing it, if it's much better, then pull the kickdown inner cable out by hand. If it is stiff, it shouldn't be, and that could be the inner cable frayed, or tight in the outer cable. Don't drive the car with the kickdown cable disconnected though.
