I made this up and put a little flake on it then gave it to my mate Ian (bigbossman) who applied the letering to his usual high standard, script is the original Ford.
Rear number plate surround made from 20mm x 6mm flat bar.
Iron Cross brake pedal pad
Dashboard pic and ready for paint
Hood side panel stainless steel spears
Arvin heater
Rocket fuel block to feed the 6 carbs
These are my alternative headers i will be using from time to time.
Stainless battery holder, there are 2 of these as i'm running a propshaft driven alternator, If after a few months on the road i find the 2nd battery is not needed i will cut the top off and gut it and use it to store some tools.
Firewall mounted fuel pressure gauge.
There will be a few that won't like this
click on the pic to see. But i like my music so i'm fitting a decent stereo system that also plays DVD's on a small screen, Amp's will be mounted behind the seat.
There is also another version here
