I've got 289 with a 4 spped box in my 100e what the most likely box this is? want to put new clutch in before I fit them and need to know what to ask for.
Cheers Moles
Could be either a toploader or Borg Warner T-10 , have you got a pic of it or any other info ?
No pictures at the mo but it looks pretty similar to the ones I'm used to pullingout of Escorts and Capris
moles,this is the BW T10 on the back of my 289.Shifter normally at rear of tailshaft housing,or slightly forward of it depending on which application it was from.Photos not the best but it's the only one I've got of the trans.
Hope this helps.
A quick ID is a toploader has a removable service plate on the top and a T-10 has a removable side cover that the two shift arms come through .
